I would like know how disabled the power function CEC, only ? Because I would like access coreElec if the tv is down.
Kinds regard
Kinds regard
You can go to settings -> system -> input -> peripherals -> CEC adapter and change what you need there
How do you think that could work?
CEC works like this: signal from TV remote -> TV -> HDMI cable -> TV Box. If any part of the chain is down, signal from your remote cannot get to your box…
It’s great to have such granularity.
I was surprised
@ Vascobraga, thanks you
I speak too fast.
I had 2 small problem:
His 2 problems do not block me because I use bypass. But it would be nice to perferct
