Is that a command I can put in to disable the onboard ir receiver?
Apart from covering it in blu tack.
Having some remote problems and want to try summit?
N2 btw.
Matt
N2 btw.
Matt
Place an empty file called remote.disable in /storage/.config
Top man.
Thanks.
