I have a Sony X950H which doesn’t support TV led DV, only LLDV.
Will there be a difference from using CoreElec on the AM6B+ vs an Nvidia Shield Pro 2019? Or only for TVs that support full fat DV?
If there is a difference, can anyone recommend a movie / scene where the difference can be seen?
Thanks!
FEL is applied whether its LLDV or TV-led. Not exclusive to an output mode.
FEL vs MEL vs HDR is explored thoroughly on YT on R3S3T_9999’s content, and DMDReview
Check “Screenshot Comparisons” tab and “Youtube Comparisons”:
Saving Private Ryan is a goto check since it works improperly without FEL. The brightness pulsates and is unwatchable.
Thanks a lot! That was exactly the information I was looking for. I can clearly see the difference on my TV in Saving Private Ryan.
system
Closed
4
