Thank You!
Not enough words to say “THANK YOU JAMAL”
Thank You jamal2367 ![]()
Just as my own build finally finished successfully ![]()
Just kidding, thanks a lot man ![]()
It doesn’t matter, because now you know how to build it and you don’t have to rely on anyone else in the future. ![]()
come on man, I was so looking forward to teasing a bit more
jk of course.
At least now we’ll have more people capable of building it and that’s a good thing.
Thank you ! Here’s a suggestion of what I think would be the best but feel free to ignore it. I think this would be useful because when FEL expands the brightness, the HDR10 metadata are almost always set to 1000nits and the RPU to 4000. I would also only display L6 maxcll/fall + the source_pq value in nits.
Exactly, that’s the important thing!
Some people can now build it themselves and are no longer dependent on other people.
Also, there are two new files updated for the CPM estuary skin
Ok now I’m a bit overwhelmed with the whole thing. ![]()
@cpm Discovered a bug, if you switch from a DV file to a HDR file the values from the DV will remain.
So, you will have an HDR file, but the Dolby Vision - HDR page will report Dolby Vision values. It seems that the code forgets to clear the values when a file is changed.
L6 Min/Max Lum = BL MDL
L6 MaxCLL/FALL = BL MaxCLL/FALL
L6 Source Min/Max Lum = RPU MDL
L6 Source Min PQ/Max PQ = RPU MaxCLL/FALL
Please help me.
I’m confused…
BL MDL and maxcll are the static HDR10 values reported by mediainfo. @Chros skin has this info so it should be available.
RPU MDL, is the Source_PQ value
so I would ignore L6 MDL and only use L6 maxcll/fall
maybe we need new thread for newer CPM builds so we know which are latest etc depending on who release new builds?
So this is correct ?
L6 Source Min/Max Lum = RPU MaxCLL/FALL
L6 Source Min PQ/Max PQ = RPU MDL
I have no idea ![]()
It’s too technical for me, all those numbers… ![]()
No,
-L6 and the HDR10 BL metadata are two different things. Look at @chros skin to find out how he displays the HDR10 metadata.
-Source_PQ and L6 values are also two different things.
Source_PQ is the actual RPU MDL while L6 should match it most of the time but not always since many release group will edit it so I would only keep the L6 maxcll/fall value from L6 and take the actual RPU MDL from source_pq
Gotta say thank you to the @jamal2367 @cpm
CE team and everyone
Thank you!
Thank you very much!!!
Thank you for this release.
