The updated skins now find here.
I need a reminder on how to upload these skins. On the previous build, I added the zip file into one of the folders and uploaded it from there. With the newer build, I’m trying to upload these new skins to no avail.
Update: I’m on the Supported Add-Ons section and while it says plugin.video.themoviesb.helper is on, I don’t have script.skinvariables nor script.texturemaker. Are those essential? How do I upload them?
Try this method maybe.
System
Settings
Interface
Skin
Use the get more function
Install the default/non modded version of skin you want.
So will install Dependencies/plug ins / etc needed.
Also use the install from repository function
Under Look and feel
For same results.
Kodi repo
Kodi nerds repo
Jurialmunkey Alpha repo
Etc
For desired skin.
Then use the install from zip function
To update/overwrite existing with modded skin.
Thanks. I tried that but the error I get is “dependency on script.texturemaker could not be satisfied”.
UPDATE: I got it! I had to install the jurial munkey zip file and it got me what I needed to add the skins!
I think there is something bad regarding to AV sync since cpm11 so probably caused by newer nightly build as when I go back to cpm10 I got less if any kodi crashes once I start the stream. ( The screen was stucked and only audio was on) I also tried to built cpm build based on latest nightly but it was the same and also the flash disk where I store backups was gone. So I rolled back to cpm10. Would be nice if anybody else says if experiencing same difficulties.
Awesome work, love it!
Can you please explain the settings in the Skin Settings page?
Especially Video OSD ones
Or - if you did already, please point where this guide might be ![]()
Regards &
Thank you
just maintain which content you want to convert to dv in system ce, and the position of the logos in the osd settings. rest on standard. if I was able to utilize the cpm builds everyone is
