When i tried add kernel of dolphin to retroarch, it was downloaded but not i not see in list of kernels.
I tried a Dolphin-emu in Android. This emulator need 64bit environment. When i checked retroarch in coreelec, so retroarch was created with 32bit compiler: gcc 12.2.0. In order to compile a 64-bit application, you need a 64-bit operating system and a 64-bit compiler that is capable of generating 64-bit executables. Additionally, the libraries and dependencies used by the application also need to be available in 64-bit versions.
CoreELEC NG is 32bit user space. Use EmuELEC for 64bit emulators
Coreelec is not 64bit ?
You have to be more precise: which version?
As written above NG is 32 bit, NE and NO are 64 bit.
Ok, i tested retroarch with dolphin on ce22no in 64 bit environment. Dolphin was not started for failed of libretro core. In this time i will check firstly a state of dolphin on linux computer.
Something is broked for run on CE, but it is not big problem. It is now irrelevant this emu for low power of current amlogic chipsets. On modern phone under android are also issue with performance.
