Something has changed between the latest CoreELEC versions. TVHeadend used to work fine in the very first builds but now I´m running into problems using TVHeadend 4.2. Although set up everything just like before the Tevii only finds one mux and 6 channels.
A quick look into dmesg I ran into “ds3000_firmware_ondemand: Waiting for firmware upload (dvb-fe-ds3000.fw)…”
Lucky you - you have a working crystal ball. Mine is still in the shop!
Anyhow - I found a temp solution: Adding a mux manually solved the problem. Looks like the trouble is the initial scan.
