Dtb.img for zapi 2020 SEI500PTV . Requesting
Hello CoreELEC team,
I am using a Zapi 2020 (SEI500PTV model) TV box and want to install CoreELEC on it. Unfortunately, I couldn’t find a suitable dtb.img file for my device in the official files.
Could you please provide me with the correct dtb.img file for this model or guide me on how to get it?
My device specs:
  • CPU: Amlogic S905X2
  • RAM: 2 gb
  • CoreELEC version I want to install: (add version)
Thanks a lot for your support
Isn’t that a Google certified device? If so I doubt it can boot CoreELEC even with a good dtb. What happens when you attempt to boot it with the generic s905x2 2GB dtb?
I tried booting with the generic s905x2 2GB dtb.img, but the device just stuck on a red LED and didn’t boot at all.
Is there any other solution or alternative steps I can try to get CoreELEC running on this device?
Thanks for your help!
EDIT: Since it’s running ATV10 or later verified boot may not be the problem. I think you’d need to open the box up to make a UART connection to see what the error message is.
