I have had a few of these from amazon lately, they were sort of semi fake they were 32/4g but had 100mb network. I struggled to install CE using toothpick method would get the android robot. I even took a working install and put it into another box and it didn’t work ended up using a second sd Card and it worked. The last one I got to to work by going into android and selecting upgrade and pointing to a dummy zip file on the sdcard if I remember correctly. Also the last two I had were identifies as x96max-plus-A1 not _5 like yours. If you haven’t done so already try a different SDcard also I seem to remember to took about a min to boot the first time then rebooted.
Make it work
Update the box to slimbox rom then update using the USB .
Now I have an issue I want see the ce on my network using core ftp user root pass coreleec said password wrong the IMG I used is the last from the nightly any idea what is the password?
