I am gotten dual boot working with Beelink mini-2 (s905x3). From cold boot, it will boot to CoreElec. From CoreElec I can choose to reboot or boot to Android ( reboot to emmc/nand ).
That’s totally fine.
But when in Android, a reboot will actually boot back into CoreElec. I would like have a choice of from Android, to reboot back to Android without going through a fully booted CoreElec.
There is a reboot option on some Android boxes called “Fast Reboot”. Rebooting with that option
always reboots to Android, even with uSD card inserted.
Btw, Android supports various reboot options: Reboot, Fast Reboot, Reboot to Recovery, Reboot to Bootloader, and Reboot to SafeMode. It’s just a question which ones are enabled by manufacturer…
There is a way to reboot back to Android by editing the aml_autoscript, but it means I have to write an apk to edit the script to boot to Android or CoreElec.
This question should be addressed to Beelink. I think that they are working on an Android version that should allow this extra option to reboot to Android rather than CE.
My Belink S905X reboots to Android if I chose reboot from nand from shutdown menue
Running Android - after reboot CE starts from SD.
If I want reboot from Android to Android I remove SD card.
I don´t understand what You wanna do ?
I’m investigating various options because the rebot from android to coreelec is a bit slow, and I’m looking for solutions. I don’t know if I will find them in this way, or I will have to look for build.prop modifications.
for fast reboot or quick start
Is there a way for me to close this thread ? I think I have gotten all I need from the thread, it has served my purpose.
I figured that both CoreElec and Beelink will not do anything about this. After all it isn’t a big problem to reboot back to CoreElec then go to Android.
