Hi all,
Woke up to my Dune constantly rebooting. I snapped a pic of the errors on the screen. Is there an easy resolution here, or am I back to square one?
Any help appreciated. Thanks.
Hi all,
Your USB stick is broken - make fresh install.
@vpeter Thanks for the quick response.
Just to clarify, you’re saying the install is broken and reinstall? Or the USB stick took a dive and install to a new stick?
edit: I’m gonna throw it on a new stick to be safe, but is there a way I can pull all my config from the old drive and copy over to the new? I can’t seem to find where that data is located when I drop the USB stick onto a Debian live boot.
@Portisch The issue is I’m not able to boot into CE because it’s constantly rebooting after a kernel panic. I’m trying to figure out if there’s a way to mount the filesystem in linux (or any OS, really) so I can pull my settings from there.
However, once I get sorted out I will start making a backup for next time
Alternatively, if there’s a way to upgrade in place (assuming my USB stick is ok), I could get in and then use the backup
