Dune HD BT Remote Control R4
Hello all togehter!
I am very happy with CE on my Dune Box.
I already fixed the problem with the Okay/Enter Button on the Dune BT Remote Control R4. Special thanks to this forum for your solution.
Now, I want to try to turn ON my device ONLY with the BT Remote Control.
My english is very poor and i only understand, that there is no solution for this?
BT is not aviable when the device ist OFF?
Is this right, or do you know a special way to fix this problem?
By the way, it is VERY uncofortable for me, to use the IR remote Control to start the device and to switch to the BT remote control after the device is on.
I can not believe, that in 2025 we need 2 controllers for this player.
