Dune HD Premier 4K Pro Compatible?
Hi all,
After some Googling I deviced to upgrade my apple tv 4k for the Dune HD Premier 4K Pro since it seems to support all codecs.
While Googling I also found that CoreELEC seems to be the best option if you want play REMUX files from a NAS (currently using jellyfin).
Now I wonder if this device is also supported?
It has the following processor:
Media processor: Amlogic S905X4-K with Dolby Vision, Dolby Atmos, DTS licenses
I did get hits on the Amlogic S905X4 but I wonder if this -K version would cause any problems.
Link to the device with all specs:
No problem concerning CE with both Amlogic S905X4-J/K versions: comparison
