Hello,probably I am few years late,but I am exited to share that I received my first Dune media player,hope I can boot into CE and test some FEL files.
So which one of the Dune’s is it? ![]()
There’s no need for that; you can find out everything by searching public information.![]()
Should be Dune hd pro vision 4k, I’ll open up box tommorow.
But maybe anyone has remote.conf file for Dune R4 remote?
Not sure if this info is still up to date, but; SoC S5 S928X - #890 by clarkss12
HHmm,even the test samples,okay got it.
This has the same SOC as the Homatics 4k r plus. It should behave the same and have the same features. Is there something significantly different with this box you’re trying to point out or just showing that all the expected features work?
Well,I guess if we want to bring more people to the community,we should discuss and show as many features and possibilities as possible.
There was a time when I didn’t know anything about setting up home theater,installing coreelec was like rocket science to me.So sharing additional information would be useful,specially for newcomers.
One thing that is interesting,with DV-HDR conversion,my TV reports ycbrcr 4:4:4 12bit HDR(I know my panel will output only 10bit) and I can’t really tell the difference between 2,so my guess VS10 engine outputs very precise video data in HDR while stock video is in DVp7 format.That will very useful for people who own TV or projector without DV support.
Moved this string of posts to it’s own dedicated Dune HD Pro Vision 4k device thread since this is more about device promotion and not specifically about DV FEL.
