I’ve tried several crazycat drivers, but tvheadend says “no signal”. With the rockpro, works without problems. On N2, red led stays off. Maybe the LNB has no voltage?
I do not know why, but I compiled the latest version, deactivated the crazycat drivers and now it works fine.
Hi
Just to add another issue with CE 9.0.1 with the same card.
After a few jump over channels it stops worknig with number of following messages in dmesg:
dvb_frontend: dvb_frontend_get_frequency_limits: frequency interval: tuner
: 950000000…2150000000, frontend: 950000000…2150000000dvb_frontend: dvb_frontend_get_fre
quency_limits: frequency interval: tuner: 950000000…2150000000, frontend: 950000000…2150
000000
Here was no such issues in old Raybuntu 8.x versions.
I’ve already tried both CrazyCats, Coreelec default and kernel-DVB drivers with more-less the same results.
BR
Janusz
