This morning my EM7680 booted in sage mode.
Log file can be found here http://ix.io/3t3W
Special log entries:
Core was generated by `/usr/lib/kodi/kodi.bin --standalone -fs’.
Program terminated with signal SIGSEGV, Segmentation fault. #0 0xf50a1300 in ?? ()
[Current thread is 1 (LWP 2995)]
2021-07-15 09:17:52.437 T:4088836112 INFO: loading settings
2021-07-15 09:17:52.438 T:4088836112 ERROR: CProfileManager: error loading special://masterprofile/profiles.xml, Line 0
Failed to open file
2021-07-15 09:17:52.438 T:4088836112 NOTICE: special://profile/ is mapped to: special://masterprofile/
2021-07-15 09:17:52.438 T:4088836112 FATAL: unable to load profile
Thanks for uor answer, I found out the profiles.xml file was trunctetd to 0 bytes because the storage was full with thumbnails. I deleted the thumbnails and the truncted profiles.xml and the system booted again normally.
I tried updating the EM7680, but I do not have any updatechannel available and no Available versions too. Any suggestions how to start an update?
9.0.1 is so old, that it’s probably best to go with a clean install of CE 19.
You could do a backup, and then try to update manually, no guarantees about that succeeding (depends a lot of the addons you have installed). To update, download the CE19 tar file and drop it in the Update (storage/.update) folder and then reboot.
