Hi there,
I installed the new EmuElec 4.0 on my Odroid N2+ and now i have some questions about it:
1.) It should be possible to have dolphin on the N2 (S922x device) , but I can’t see it anywhere! I tried to add the “dolphin-data.zip” in Retroarch (Main Menu/Online Updater/Content Downloader/Nintendo-GameCube-WII), but nothing happens after that. I’m not able to find the Dolphin Core or something like e.g. “GameCube”. In Emulationstation the same, nothing appears there.
2.) And, if it is present, where can I place my GameCube-roms? I even can’t find a folder for it! Do I have to create it manually? And how is it’s name?
3.) In previous versions of EmuElec I had force feedback (vibration) on my Logitech Cordless Rumblepad 2.0 in some games (e.g. Rush 2049), but now it’s totally gone! I also could set the feedback on Retroarch (Settings/Input/Haptic Feedback/Vibration), but now it only shows “No Settings Found”.
4.) In Emulationstation the configuring of my controller Logitech Cordless Rumblepad 2.0 is not working in the analog section! Both analog sticks are not recognized. For a working setup I have to do this in Retroarch, then it works even under Emulationstation. This behaviour appeared some versions earlier, I think since EmuElec 3.6 or so. Before it worked without problems.
Ok, that’s it for the moment. I hope that there are some solutions for my requests…
And please don’t think that I only want to criticize the project – no, of course not, You are doing a very great job and many thanks for all of your phantastic work!
