Recently, I install EmuELEC in the X96 air amlogic s905x3 4Gb version. Everything work fine except there is no way to output sound through 3.5mm audio jack. I already try to change some settings in alsamixer but no result. The android stock image has the 3.5mm audio jack output without any configuration.
It there any way to choose audio output? Thank you.
Here is some information about the system:
- EmuELEC version 3.4
- X96 air amlogic s905x3 4Gb ram
- Have try all the setting EmuELEC provide in main menu. Audio output in system setting have only auto option. Audio devices in EMUELEC setting have more setting like (0,0),(0,1) but nothing work. Sound setting in image below.
- play -L output:
null Discard all samples (playback) or generate zero samples (capture) sysdefault:CARD=AMLAUGESOUND AML-AUGESOUND, Default Audio Device surround71:CARD=AMLAUGESOUND,DEV=0 AML-AUGESOUND, 7.1 Surround output to Front, Center, Side, Rear and Woofer speakers iec958:CARD=AMLAUGESOUND,DEV=0 AML-AUGESOUND, IEC958 (S/PDIF) Digital Audio Output hdmi:CARD=AMLAUGESOUND,DEV=0 AML-AUGESOUND, HDMI Audio Output
- amixer scontrols output (already try most of them but no success)
Simple mixer control âLineout left N switchâ,0
Capabilities: enum Items: 'None' 'LOLN_SEL_DACL_INV' 'LOLN_SEL_DACL' Item0: 'LOLN_SEL_DACL_INV' Simple mixer control 'Lineout left P switch',0 Capabilities: enum Items: 'None' 'LOLP_SEL_DACL' 'LOLP_SEL_DACL_INV' Item0: 'LOLP_SEL_DACL' Simple mixer control 'Lineout right N switch',0 Capabilities: enum Items: 'None' 'LORN_SEL_DACR_INV' 'LORN_SEL_DACR' Item0: 'LORN_SEL_DACR_INV' Simple mixer control 'Lineout right P switch',0 Capabilities: enum Items: 'None' 'LORP_SEL_DACR' 'LORP_SEL_DACR_INV' Item0: 'LORP_SEL_DACR' Simple mixer control 'I2SIn CLK',0 Capabilities: enum Items: '0' '3000000' '6000000' '12000000' Item0: '0' Simple mixer control 'AED Clip THD',0 Capabilities: volume volume-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 8388607 Mono: 8388607 [100%] Simple mixer control 'AED DC cut enable',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'AED EQ enable',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'AED Full-band DRC enable',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'AED Lch volume',0 Capabilities: volume volume-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 255 Mono: 207 [81%] Simple mixer control 'AED Multi-band DRC enable',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'AED Noise Detect enable',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'AED Rch volume',0 Capabilities: volume volume-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 255 Mono: 207 [81%] Simple mixer control 'AED master volume',0 Capabilities: volume volume-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 1023 Mono: 831 [81%] Simple mixer control 'Audio In Source',0 Capabilities: enum Items: 'TDMIN_A' 'TDMIN_B' 'TDMIN_C' 'SPDIFIN' 'PDMIN' 'FRATV' 'TDMIN_LB' 'LOOPBACK_A' 'FRHDMIRX' 'LOOPBACK_B' 'SPDIFIN_LB' 'EARCRX_DMAC' 'RESERVED_0' 'RESERVED_1' 'RESERVED_2' 'VAD' Item0: 'VAD' Simple mixer control 'Audio Out Sink',0 Capabilities: enum Items: 'TDMIN_A' 'TDMIN_B' 'TDMIN_C' 'SPDIFIN' 'PDMIN' 'FRATV' 'TDMIN_LB' 'LOOPBACK_A' 'FRHDMIRX' 'LOOPBACK_B' 'SPDIFIN_LB' 'EARCRX_DMAC' 'RESERVED_0' 'RESERVED_1' 'RESERVED_2' 'VAD' Item0: 'VAD' Simple mixer control 'Audio hdmi-out mute',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'Audio spdif format',0 Capabilities: enum Items: '2 CH PCM' 'DTS RAW Mode' 'Dolby Digital' 'DTS' 'DD+' 'DTS-HD' 'Multi-channel LPCM' 'TrueHD' 'DTS-HD MA' 'HIGH SR Stereo LPCM' Item0: '2 CH PCM' Simple mixer control 'Audio spdif mute',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'Audio spdifin source',0 Capabilities: enum Items: 'spdifin pad' 'spdifout' 'N/A' 'HDMIRX' Item0: 'spdifin pad' Simple mixer control 'DAC Digital',0 Capabilities: pvolume Playback channels: Front Left - Front Right Limits: Playback 0 - 255 Mono: Front Left: Playback 251 [98%] [-11.25dB] Front Right: Playback 251 [98%] [-11.25dB] Simple mixer control 'DAC Extra Digital Gain',0 Capabilities: enum Items: '0dB' '6dB' '12dB' '18dB' Item0: '0dB' Simple mixer control 'LPCM',0 Capabilities: pvolume Playback channels: Front Left - Front Right Limits: Playback 0 - 255 Mono: Front Left: Playback 255 [100%] [0.00dB] Front Right: Playback 255 [100%] [0.00dB] Simple mixer control 'SPDIF CLK Fine Setting',0 Capabilities: volume volume-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 2000000 Mono: 5644797 [282%] Simple mixer control 'SPDIFIN Audio Type',0 Capabilities: enum Items: 'LPCM' 'AC3' 'EAC3' 'DTS' 'DTS-HD' 'TRUEHD' 'PAUSE' Item0: 'LPCM' Simple mixer control 'SPDIFIN audio samplerate',0 Capabilities: enum Items: 'N/A' '32000' '44100' '48000' '88200' '96000' '176400' '192000' Item0: 'N/A' Simple mixer control 'TDM MCLK Fine Setting',0 Capabilities: volume volume-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 2000000 Mono: 12287994 [614%] Simple mixer control 'VAD',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'VAD Source sel',0 Capabilities: enum Items: 'TDMIN_A' 'TDMIN_B' 'TDMIN_C' 'SPDIFIN' 'PDMIN' 'LOOPBACK_B' 'TDMIN_LB' 'LOOPBACK_A' Item0: 'PDMIN' Simple mixer control 'VAD Test',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'VAD enable',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'audio inskew set',0 Capabilities: enum Items: '0' '1' '2' '3' '4' '5' '6' Item0: '0' Simple mixer control 'audio locker enable',0 Capabilities: enum Items: 'Disable' 'Enable' Item0: 'Disable' Simple mixer control 'tdmout_c binv set',0 Capabilities: enum Items: '0' '1' Item0: '0'
