Emuelec Nokia 8010 not working properly
I think this TV Box model is a rebranded Homatics Box R4k plus. I used an usb stick to do a clean install with EE 4.7. As device tree I am using sc2_s905x4_4g_1gbit.dtb. The problem is that in my LG C9 at 1080 60Hz the screen has a greenish colour and if I change to a higher resolution the screen just renders the top making it impossible to change back to 1080. Am I using the wrong DTB?
Im using EE4.8 on dune box with the same DTB. Dune Box is same as homatics or Nokia box. Using same resolution 1080p@60hz on Philips oled with no issues.
Thanks for replying. I’m gonna give it a go. I haven’t tried 4.8.
I can confirm that 4.8 works flawlessly with that DTB. Many thanks.
