I know , this is no emuElec forum , but maybe someone can help.
Sometimes I have no ethernet connection. After reboot one or two times it’s working.
The other problem is I can’t shut down the box. The box turned automatically on again after choosing shutdown .
That’s exactly the same problems like coreELEC on this box at the beginning of supporting.
If I remember correctly, after modifications on the DTB.img the problems was solved.
So I tried to use the DTB.img from coreELEC, but it will not boot. Any ideas how to fix this two things ?
It is Homatics Box R4k plus device with fresh and clean install with EE 4.7. As device tree it is using sc2_s905x4_4g_1gbit.dtb . And yes , I use the menu with select button and choose shutdown.
The second issue I have is the ethernet. Sometimes it works , sometimes not. Have to reboot 2-3 times.
With coreELEC I use sc2_s905x4_sei_smb_280.dtb maybe it’s important…
And thanks for version 4.7 … It runs so much better than 4.6 … Nice work, love it …
