I’ve got a Jenkins pipeline to build weekly releases on latest master commit, .tar pkg builds correctly and I can install it on my development box, but make fails complaining about a missing file.
Creating Amlogic ZIP update package
cp: cannot stat '/var/lib/jenkins/workspace/coreelec/projects/Amlogic/install/update-binary': No such file or directory
Any ideas? Thanks!
We don’t use make amlpkg
for any of our releases, we use make image
, maybe changing the command will help.
Solved, now the pipeline builds and install it on the device. thanks!
Do you know if is there any kind of tests I could run on the device to check the release? Would be interesting to have such a thing.
you can cat /etc/os-release
for specific release information
Sorry, I didn’t explained myself correcty. I meant if there is somethig like testing video playback (different streams, video bitrates), DVB, performance tests… you name it
