Hi, I am trying to use CE to rip audio cds. When I insert the disc it gives an error after a few seconds of reading, “CDDB: Error Open Socket”
If I click ok on that prompt, it proceeds to rip but does not download any metadata. I am guessing the error is because kodi is unable to connect to cddb. I am not sure if this is due to Kodi or coreelec.
Debug log attached. Any help is highly appreciated.
Considering the fix was made in the advancedsettings.cpp file, it’s very likely that you just need to create your own advancedsettings.xml with the correct URL.
