EDIT: SOLVED:
TL:DR:
search online for firmware “HQYG-TX7-nikodi-20180104” , and flash it.
Then follow standard procedure to boot coreelec ng and install to internal.
This procedure may work for other s905x 2g devices as well.
Full version
the installation to internal fails because the bootloader is old and not compatible with ng’s kernel 4.9.
Installing a newer firmware from a different device solves this problem.
this procedure may work for other s905x 2g devices as well.
As posted by kshi in this thread
flashing firmware “HQYG-TX7-nikodi-20180104” which is nougat 7.1.2 for device tx7 did the trick for my device as well.
I haven’t tested the android rom, but it is now possible to boot coreelec and install it to internal using ceemmc
----------------- Original Post---------
can someone advjice on how to proceed with the following problem?
I can restore the original firmware if needed and use terminal if given instructions
tl:dr:
On a s905x device I cant install ng build to internal using ceemmc tool. the error message is:
Warning: Could not find ‘dtbo’ partition!
Warning: Could not find ‘dto’ partition!
Error dtb magic: a!
Could not remove node ‘/partitions’ from dtb0!
Full version:
Hi, my device is a Beelink Mini MXIII II. It’s a s905x, 2gb of ram and everything that I could test works fine either in ng or older kernel builds, with device tree gxl_p212_2g.
Installing to internal works fine for older builds usung installtointernal command,
but although I can boot from usb and run ng build 9.4,2,
trying to install it using ceemmc tool with -x flag fails.
this is the terminal output:
Please choose one option? [1/2/3/4]: 3
Free space of ‘partition CE_FLASH’: 512MB
Free space of ‘partition CE_STORAGE’: 29144MB
Used space of ‘/flash’: 221MB
Used space of ‘/storage’: 12MB
There is enough free space on eMMC for installation!
Install CoreELEC on eMMC.
Continue? [y]: y
Error dtb magic: a!
Failed to write the new partition table to eMMC!
I hope I posted in the right place.
thanks in advance,
Vassilis
