Hello, I have a bit of an odd problem, Nodes are not working with CoreElec in combination with Estuary Mod V2 (generic S905X3 box), I tried with Node Editor but it did not create the necessary folder/files in “userdata/library” and if I create them manually it doesn’t work either, I end up with empty Nodes, I can use dynamic playlists but their functionality is more limited and I have to create a lot of them instead of just a few Nodes.
If someone has a solution ti would be greatly appreciated, thanks in advance.
