The ethernet port LED’s on my N2+ stay on when the device has been shut down and when it’s in suspend mode. Is this normal behavior? The green LED is solid, and the amber one blinks intermittently.
If this is normal, is there a way to turn off ethernet at shutdown/suspend, or, failing that, to turn off the LED’s?
Running 19.2-Matrix_rc2 and latest petitboot. I have wake on lan set to 0 in config.ini
Okay, if that’s normal behavior, I’m fine with it. Just wanted to make sure my computer hadn’t become self-aware and hacked itself into the matrix when I wasn’t looking.
On the N2+ WoL and USB Power can’t be activated, it’s been like this over many previous builds as well. You can switch them on, back up out of the menu and re-enter and they will be disabled again.
I thought WoL used to work but it doesn’t any longer as it can’t be enabled.
Don’t know about any other explanations for "config.ini"entries other than those already contained in the file.
I run CE 9.2.7 on my N2 and in my default config.ini I have those settings for WoL.
Btw, I can send you default config.ini which somehow seems to be missing on your instalation.
