The Test Files folder contains Video and Audio sample test files and I do not want these to be included in the Movies Library. So I added a .nomedia file to that folder, however this is not excluding those files.
Is there a way to exclude this folder from the library?
I also use it, but if I remember correctly, there was a “trick” to how to create that file. Especially if you’re using Windows. I think it was a trick to prevent Windows from creating it as a text file or something like that.
