Hello, just a little message to inform you that my tool eXoDOSConverter is now compatible with emuelec.
Keep in mind though that this is a brand new feature, I followed the wiki page about DOS on Emulec’s github, but I don’t one any EmuELEC powered device, so ultimately I need testers to check that everything works fine, so feel free to enter an issue on the project’s github if you encounter any trouble.
Ultimately this tool in combination with the collection might be the easiest way to play DOSBox on EmuELEC
What’s eXoDOS ?
For those of you for which this name doesn’t mean anything, ExoDOS Collection is a collection of DOS games and in my opinion the best one as it includes full, correct configuration for all games.
It is based on Launchbox and Windows only though The collection is supported in its V5 full version only, V4 support has been dropped
Lite version will be likely supported later with Download on demand implemented in the converter, if it’s feasible
There’s also an ExoDOSWin3x collection for Windows 3.1 games, version 2 of which will be supported when it’s released
Before using this tool, don’t forget to install the collection with its setup.bat
