How to find exact info for path to external drive?
I need to point tvheadend to a folder on my external drive, but everything i look at seems to list or show it in a different way?
Yes i get where exactly to put it in, but it never seems to work?
So my drive is labeled KODI DISK, and i want to record the the RECORDING folder?
Shows storage space 0/0/0
Ensure that your disk mounted properly, have proper permissions and you typed the path correctly
On my device is in /media/<usb-disk>
My recordings are in /media/<usb-disk>/recordings
Its mounted properly, im just not sure exactly what i should be typing?
Including spaces in names of disks, directories, files, etc. It’s always a problem, replace the spaces with a printable character (I use: . - _ @).
Note: I am not an expert in programming and perhaps someone more expert can help us. If there are spaces in a name, perhaps it can be solved by typing \s or $(<name-with-spaces>).
Also try to use a Linux formatted disk as otherwise recordings tend not to get listed in Kodi for permissions reasons.
I second the advice to avoid spaces as they are not recognised and the label stops been read at the space.
Whenever I include <...> it indicates that it is a custom value dependent on hardware and software installed. This is an agreement normally admitted in programming.
Search your directory /media and you will see the name of your hard drive
Sorted it now guys thanks, my path is “var/media/KODI DISK/80 - RECORDINGS”
This is what had originally but it just started working for some reason, showing 3230/0/7451GiB
Recording now working great.
