Failed to update /lib/firmware dir
I tried the latest Amlogic-no (New Order). CoreELEC-Amlogic-no.aarch64-22.0-Piers_alpha1-Generic.img downloaded from this forum. the installation went through well . But if found out a lot of files missing in /lib/firmware. I tried to copied some files to this dir. and double chechk the copied files does reach the dest. However , after reboot , the files are all missing. :smiley: the firmware dir. ( soft link to /run/kernel-overlays/firmware ) has the following attributes : drwxr-xr-x 23 root root 4660 Jan 1 1970 firmware/
I check my identity : CoreELEC:/run/kernel-overlays # whoami root
Franly speaking , I cannot figure out what is wrong . Could you please tell me is it a expected behhave ?
Your first problem is that you don’t say what exactly is wrong.
This is not true :slight_smile:
To add any missing file the correct location is /storage/.config/firmware.
And to resolve any issue the first thing is to use nightly build.
Thanks for the tips ~~~ I finally collect the firmwares and am sure everything is read :slight_smile:
For dmesg info , please refer to : Ubuntu Pastebin
For udevadm log , please refer to : [udevadm_log - Pastebin.com]udevadm_log - Pastebin.com
Unfortunately , I didnot find the related tools ( nmcli or bluetoothctl or any NetworkManager tools . The system OS does not has any button/interface to scan wifi network either . How does the system works if user has only wifi connection please ?
Linux version 5.15.153
First thing is to check nightly where all the work is done.
bluetoothctl is available
Of course it have it: under CE settings addon. Obviosuly only works if there is wifi interface.
Works like with ethernet?
Thanks for your help :slight_smile: I finally found the wifi networks at the connection column :smiley:
During the test , only one strange issue : If I reboot the system , all of the connections ( wifi networks ) lost. I had to disable the “active” option under the wireless networks menu,
and enable it again. After that , all of the connections appears as before. Is that any expected behavior ?
Cheer ~~
This happens by some big sometimes.
Make a new clean fresh install and it should be enabled always again on boot.
