Currently, we can set updates to auto or manual. Manual does not mean we won’t be prompted to install update - alert to install update will pop up on every boot. My proposal is to add third option “disabled” and CoreElec won’t even check for updates.
As I can see, “manual” option is somehow confusing, most people think that means “disabled” and updates must be sideloaded manually, which is not true
