Skunz
1 December 2023 14:15
1
Hi I have and Odroid N2 with amlogic-ng version 21 Nightly.
Is it possible to include Fnvi FU-AX 1800 in the next drop ?
The Dongle use the mt7921au chipset and the standard Mediatek device ID (VID/PID) for the mt7921au chipset: ID 0e8d:7961
More details here:
## USB WiFi adapters that are supported with Linux `in-kernel` drivers
USB WiFi adapters that are supported with `in-kernel` drivers are plug-and-play with most desktop distros. Additional work may be required for server distros as the maintainers of server distros seem to think that there are ethernet cables everywhere a user may choose to locate a server. Linux `in-kernel` drivers are preferable over `out-of-kernel` drivers for most users and use cases as problems with locating, installing and maintaining drivers are dramatically reduced allowing for a better experience.
Note: All USB WiFi adapters listed here are single-state (no Windows driver inside), single-function (no Bluetooth support) and use in-kernel drivers (Plug and Play). Buying adapters that meet this criteria greatly increases the probability of a satisfying experience.
Recent changes:
- 2023-10-15 - checked and updated adapter links and prices.
- 2023-09-21 - added Fenvi FU-AX1800 (AXE3000) to mt7921au chipset section.
- 2023-07-05 - added ALFA AWUS036AXM (AXE3000) to mt7921au chipset section.
- 2023-05-18 - added ALLNET ALL-WA1200AC (AC1200) to mt7612u chipset section.
- 2023-05-17 - updated ALFA AWUS036ACU (AC1200) to rtl8812bu chipset section.
- 2023-04-10 - added BrosTrend AC3L (AC1200) to rtl8812bu chipset section.
- 2023-03-05 - deleted some old adapters that were overpriced.
- 2023-02-15 - added Panda PAU0B (AC600) to the mt7610u chipset section.
- 2023-02-01 - added ALFA AWUS036AXML (AXE3000) to mt7921au chipset section.
- 2023-02-01 - added Netgear A8000 (AXE3000) to mt7921au chipset section.
This file has been truncated. show original
Thanks in advance
Not yet in future. Your device will require kernel version 5.17.0 minimum to include the driver.
We are currently working on 5.15.78 and there is only the PCI driver for this ID included.
Skunz
6 December 2023 11:06
3
Thanks a lot.
Are you able to suggest me any working wifi6 usb adapter for Coreelec ?
SKunz
system
Closed
20 December 2023 11:06
4
