First i must say, im amazed what coreelec builders did - amazing job! thank you!
But the problem is, when i use S905x3(s96 max plus 4/32gb) with coreelec and ffmpeg, then i can use only one ffmpeg process in time. I have setup in kodi and android, all working as need, can but record as many recordings with ffmpeg as i want, but when i use same system in Coreelec, then i can record only one channel same time and if i but one channel record and try to go watch same time another channel, then i hear only audio, but screen black(i used right ffmpeg build in coreelec, all working as need, exept that i can but only one recording in time).
Maybe someone faced same problem and can help me ?
ANd sorry, if i posted to wrong place… i hope its right place
