Fix display resulution
Hey I have a similar problem as here discribed:
I disconnect my box and the tv from the grid after using it for just once a week. When I turn it both back on again the box seems to be back faster than my tv so the box switch to a lower resulution than 1080p as I set it up in the settings.
Delaying the startup process of the box as adviced in the old thread is not a propper sulution in my opinion.
My question now is: is it possible to force the system to boot up in 1080p even it can’t detect an output strait away?
Yes, with SSH commands:
fw_setenv hdmimode 1080p50hz
fw_setenv outputmode 1080p50hz
or
fw_setenv hdmimode 1080p60hz
fw_setenv outputmode 1080p60hz
I would try a different HDMI cable first.
If your box is Amlogic, turn on Display, then turn on box, and then run cat /sys/class/amhdmitx/amhdmitx0/disp_cap > /storage/.kodi/userdata/disp_cap through SSH.
After this, even when you restart the box during shutdowned Display, Kodi dont loose display’s capabilities memory.
I did this on Amlogic, if your box is Rpi, then you need to store edid through tvservice -d /flash/edid command and then add a few commands to the config.txt.
