Since 9.0.1 (jumped from 8.99.2) I can see occasionally
ERROR: OnTvStandby - Unexpected [standby_pc_on_tv_standby] setting value
error messages. I dont use any CEC related settings (everything off or ignored), using CEC just for control CE.
<settings>
<setting id="activate_source" value="0" />
<setting id="button_release_delay_ms" value="0" />
<setting id="button_repeat_rate_ms" value="0" />
<setting id="cec_hdmi_port" value="1" />
<setting id="cec_standby_screensaver" value="0" />
<setting id="cec_wake_screensaver" value="0" />
<setting id="connected_device" value="36037" />
<setting id="device_name" value="Kodi" />
<setting id="device_type" value="1" />
<setting id="double_tap_timeout_ms" value="300" />
<setting id="enabled" value="1" />
<setting id="pause_or_stop_playback_on_deactivate" value="231" />
<setting id="pause_playback_on_deactivate" value="0" />
<setting id="physical_address" value="0" />
<setting id="power_avr_on_as" value="0" />
<setting id="send_inactive_source" value="0" />
<setting id="standby_devices" value="231" />
<setting id="standby_devices_advanced" value="" />
<setting id="standby_pc_on_tv_standby" value="36028" />
<setting id="standby_tv_on_pc_standby" value="0" />
<setting id="tv_vendor" value="0" />
<setting id="use_tv_menu_language" value="0" />
<setting id="wake_devices" value="231" />
<setting id="wake_devices_advanced" value="" />
</settings>
Anyone experience this? Its from CEC, and it shows on LG, Phillips. I think its triggered by turning TV off (when CE is running 24/7).
I believe, thats because Ignore - 36028 is somehow missing on PeripheralCecAdapter.cpp’s
void CPeripheralCecAdapter::OnTvStandby(void)
