Hi all,
CE 9.0.1 - S912 TX92
When playing the video below I get the normal black strips at the top and bottom of the screen, however the bottom one is continually flickering from black to white to greys.
The top one remains a constant black.
Any ideas appreciated.
TIA
Greg
> General
> Unique ID : 18366671169436067048902544370765179739 (0xDD14ACD838E28BA0387D520881CAB5B)
> Complete name : M:\Movie.2160p.BluRay.x265.10bit.HDR.DTS-HD.MA.TrueHD.7.1.Atmos-SWTYBLZ.mkv
> Format : Matroska
> Format version : Version 4
> File size : 4.73 GiB
> Duration : 21 min 55 s
> Overall bit rate mode : Variable
> Overall bit rate : 30.9 Mb/s
> Movie name : Movie.2160p.BluRay.x265.10bit.HDR.DTS-HD.MA.TrueHD.7.1.Atmos-SWTYBLZ
> Encoded date : UTC 2019-02-07 19:46:15
> Writing application : mkvmerge v30.1.0 ('Forever And More') 64-bit
> Writing library : libebml v1.3.6 + libmatroska v1.4.9
> Cover : Yes
> Attachments : small_cover.jpg / small_cover_land.jpg / cover.jpg / cover_land.jpg
> Video
> Format : HEVC
> Format/Info : High Efficiency Video Coding
> Commercial name : HDR10
> Format profile : Main 10@L5.1@High
> Codec ID : V_MPEGH/ISO/HEVC
> Duration : 21 min 54 s
> Bit rate : 16.6 Mb/s
> Width : 3 840 pixels
> Height : 1 606 pixels
> Display aspect ratio : 2.40:1
> Frame rate mode : Constant
> Frame rate : 23.976 (24000/1001) FPS
> Color space : YUV
> Chroma subsampling : 4:2:0 (Type 2)
> Bit depth : 10 bits
> Bits/(Pixel*Frame) : 0.112
> Stream size : 2.54 GiB (54%)
> Title : Movie.2160p.BluRay.x265.10bit.HDR.DTS-HD.MA.TrueHD.7.1.Atmos-SWTYBLZ
> Writing library : x265 3.0_RC+13-ae085e5cd8a2:[Windows][GCC 8.2.1][64 bit] 10bit
> Encoding settings : cpuid=1111039 / frame-threads=16 / numa-pools=24,24,24,24 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x1606 / interlace=0 / total-frames=0 / level-idc=51 / high-tier=1 / uhd-bd=0 / ref=3 / no-allow-non-conformance / repeat-headers / annexb / aud / hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=1 / keyint=24 / gop-lookahead=0 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=25 / lookahead-slices=4 / scenecut=40 / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=2 / limit-refs=3 / no-limit-modes / me=1 / subme=2 / merange=57 / temporal-mvp / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / no-sao / no-sao-non-deblock / rd=3 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=0.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=16.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / vbv-maxrate=160000 / vbv-bufsize=160000 / vbv-init=0.9 / crf-max=0.0 / crf-min=0.0 / ipratio=1.40 / pbratio=1.30 / aq-mode=1 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=1 / chromaloc-top=2 / chromaloc-bottom=2 / display-window=0 / master-display=G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,50) / max-cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / opt-qp-pps / opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / hdr / hdr-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=5 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=0 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / qp-adaptation-range=1.00
> Default : Yes
> Forced : No
> Color range : Limited
> Color primaries : BT.2020
> Transfer characteristics : PQ
> Matrix coefficients : BT.2020 non-constant
> Mastering display color primaries : Display P3
> Mastering display luminance : min: 0.0050 cd/m2, max: 1000 cd/m2
> Audio #1
> Format : MLP FBA 16-ch
> Format/Info : Meridian Lossless Packing FBA with 16-channel presentation
> Commercial name : Dolby TrueHD with Dolby Atmos
> Codec ID : A_TRUEHD
> Bit rate mode : Variable
> Bit rate : 7 218 kb/s
> Maximum bit rate : 8 331 kb/s
> Channel(s) : 8 channels
> Channel layout : L R C LFE Ls Rs Lb Rb
> Sampling rate : 48.0 kHz
> Frame rate : 1 200.000 FPS (40 SPF)
> Compression mode : Lossless
> Stream size : 1.10 GiB (23%)
> Title : Dolby TrueHD with Dolby Atmos
> Language : English
> Default : Yes
> Forced : No
> Number of dynamic objects : 13
> Bed channel count : 1 channel
> Bed channel configuration : LFE
> Audio #2
> Format : DTS XLL
> Format/Info : Digital Theater Systems
> Commercial name : DTS-HD Master Audio
> Codec ID : A_DTS
> Bit rate : 6 350 kb/s
> Channel layout : C L R LFE Lb Rb Lss Rss
> Frame rate : 93.750 FPS (512 SPF)
> Bit depth : 24 bits
> Stream size : 996 MiB (21%)
> Title : DTS-HD Master Audio
> Language : English
> Default : No
> Forced : No
> Audio #3
> Format : AC-3
> Format/Info : Audio Coding 3
> Commercial name : Dolby Digital
> Codec ID : A_AC3
> Bit rate mode : Constant
> Bit rate : 640 kb/s
> Channel(s) : 6 channels
> Frame rate : 31.250 FPS (1536 SPF)
> Bit depth : 16 bits
> Compression mode : Lossy
> Stream size : 100 MiB (2%)
> Title : Dolby Digital AC-3
> Language : English
> Service kind : Complete Main
> Default : No
> Forced : No
> Text #1
> Format : UTF-8
> Codec ID : S_TEXT/UTF8
> Codec ID/Info : UTF-8 Plain Text
> Duration : 20 min 13 s
> Bit rate : 36 b/s
> Count of elements : 219
> Stream size : 5.48 KiB (0%)
> Title : English-SRT
> Language : English
> Default : Yes
> Forced : No
> Text #2
> Format : UTF-8
> Duration : 21 min 2 s
> Bit rate : 41 b/s
> Count of elements : 247
> Stream size : 6.34 KiB (0%)
> Title : English-SDH-SRT
> Language : English
> Default : No
> Forced : No
> Text #3
> Format : PGS
> Muxing mode : zlib
> Codec ID : S_HDMV/PGS
> Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
> Duration : 21 min 41 s
> Bit rate : 29.0 kb/s
> Count of elements : 496
> Stream size : 4.51 MiB (0%)
> Title : English-PGS
> Language : English
> Default : No
> Forced : No
> Text #4
> Format : PGS
> Muxing mode : zlib
> Duration : 14 min 7 s
> Bit rate : 3 418 b/s
> Count of elements : 44
> Stream size : 354 KiB (0%)
> Title : Spanish-PGS
> Language : Spanish
> Default : No
> Forced : No
> Text #5
> Format : PGS
> Muxing mode : zlib
> Duration : 20 min 50 s
> Bit rate : 8 199 b/s
> Count of elements : 150
> Stream size : 1.22 MiB (0%)
> Title : French-PGS
> Language : French
> Default : No
> Forced : No
> Text #6
> Format : PGS
> Muxing mode : zlib
> Duration : 17 min 12 s
> Bit rate : 2 555 b/s
> Count of elements : 46
> Stream size : 322 KiB (0%)
> Title : Spanish-PGS
> Language : Spanish
> Default : No
> Forced : No
> Text #7
> Format : PGS
> Muxing mode : zlib
> Bit rate : 2 610 b/s
> Stream size : 329 KiB (0%)
> Title : Danish-PGS
> Language : Danish
> Default : No
> Forced : No
> Text #8
> Format : PGS
> Muxing mode : zlib
> Bit rate : 1 992 b/s
> Count of elements : 36
> Stream size : 251 KiB (0%)
> Title : Dutch-PGS
> Language : Dutch
> Default : No
> Forced : No
> Text #9
> Format : PGS
> Muxing mode : zlib
> Bit rate : 2 969 b/s
> Count of elements : 48
> Stream size : 374 KiB (0%)
> Title : Finnish-PGS
> Language : Finnish
> Default : No
> Forced : No
> Text #10
> Format : PGS
> Muxing mode : zlib
> Duration : 18 min 16 s
> Bit rate : 8 689 b/s
> Count of elements : 138
> Stream size : 1.14 MiB (0%)
> Title : German-PGS
> Language : German
> Default : No
> Forced : No
> Text #11
> Format : PGS
> Muxing mode : zlib
> Bit rate : 2 821 b/s
> Count of elements : 50
> Stream size : 356 KiB (0%)
> Title : Italian-PGS
> Language : Italian
> Default : No
> Forced : No
> Text #12
> Format : PGS
> Muxing mode : zlib
> Duration : 20 min 53 s
> Bit rate : 12.5 kb/s
> Count of elements : 224
> Stream size : 1.87 MiB (0%)
> Title : Japanese-PGS
> Language : Japanese
> Default : No
> Forced : No
> Text #13
> Format : PGS
> Muxing mode : zlib
> Bit rate : 2 952 b/s
> Stream size : 372 KiB (0%)
> Title : Norwegian-PGS
> Language : Norwegian
> Default : No
> Forced : No
> Text #14
> Format : PGS
> Muxing mode : zlib
> Bit rate : 2 349 b/s
> Count of elements : 40
> Stream size : 296 KiB (0%)
> Title : Swedish-PGS
> Language : Swedish
> Default : No
> Forced : No
> Text #15
> Format : PGS
> Muxing mode : zlib
> Bit rate : 21.1 kb/s
> Count of elements : 354
> Stream size : 3.15 MiB (0%)
> Title : Chinese-PGS
> Language : Chinese
> Default : No
> Forced : No
> Text #16
> Format : PGS
> Muxing mode : zlib
> Bit rate : 2 543 b/s
> Stream size : 321 KiB (0%)
> Title : Czech-PGS
> Language : Czech
> Default : No
> Forced : No
> Text #17
> Format : PGS
> Muxing mode : zlib
> Bit rate : 16.6 kb/s
> Count of elements : 438
> Stream size : 2.48 MiB (0%)
> Title : Korean-PGS
> Language : Korean
> Default : No
> Forced : No
> Text #18
> Format : PGS
> Muxing mode : zlib
> Bit rate : 18.3 kb/s
> Stream size : 2.74 MiB (0%)
> Title : Chinese-PGS
> Language : Chinese
> Default : No
> Forced : No
> Text #19
> Format : PGS
> Muxing mode : zlib
> Bit rate : 1 937 b/s
> Count of elements : 34
> Stream size : 244 KiB (0%)
> Title : Polish-PGS
> Language : Polish
> Default : No
> Forced : No
