I am running CE 9.0.3 and 9.0.2 and I am having a problem with FLIRC disconnecting. I am not sure if the issue is power supply or CE.
The DMESG shows that the USB continues disconnecting. Here is a short example:
input: flirc.tv flirc as /devices/dwc2_b/usb1/1-1/1-1.3/1-1.3:1.0/0003:20A0:0001.0004/input/input6
[ 43.253142@0] hid-generic 0003:20A0:0001.0004: input,hidraw0: USB HID v1.01 Keyboard [flirc.tv flirc] on usb-dwc2_b-1.3/input0
[ 43.660352@0] usb 1-1.3: USB disconnect, device number 11
[ 45.172601@2] usb 1-1.3: new low-speed USB device number 12 using dwc_otg
[ 45.280211@2] usb 1-1.3: New USB device found, idVendor=20a0, idProduct=0001
[ 45.280223@2] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 45.280227@2] usb 1-1.3: Product: flirc
[ 45.280231@2] usb 1-1.3: Manufacturer: flirc.tv
[ 45.284801@2] usbhid 1-1.3:1.0: can’t add hid device: -71
[ 45.284842@2] usbhid: probe of 1-1.3:1.0 failed with error -71
[ 45.286168@2] usb 1-1.3: USB disconnect, device number 12
[ 46.712450@2] usb 1-1.3: new low-speed USB device number 13 using dwc_otg
[ 46.818795@2] usb 1-1.3: New USB device found, idVendor=20a0, idProduct=0001
[ 46.818856@2] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 46.818885@2] usb 1-1.3: Product: flirc
[ 46.818912@2] usb 1-1.3: Manufacturer: flirc.tv
[ 46.847870@2] input: flirc.tv flirc as /devices/dwc2_b/usb1/1-1/1-1.3/1-1.3:1.0/0003:20A0:0001.0005/input/input7
[ 46.852544@2] hid-generic 0003:20A0:0001.0005: input,hidraw0: USB HID v1.01 Keyboard [flirc.tv flirc] on usb-dwc2_b-1.3/input0
[ 47.245308@2] usb 1-1.3: USB disconnect, device number 13
Any suggestions on what may be the problem?
