Hi!
I would like to force the output on the HDMI, even if there is nothing connected. On my previous config, an Intel NUC running LibreElec, I added this on the boot command line, in extlinux.conf:
video=HDMI-A-1:1920x1080@50D
(the final D is the key, to force the output)
and it worked fine. But things seems different on the N2. How do I do the same?
The issue I have is each time I switch off my projector, when I switch it on again, the video is disabled, and I have to unplug/replug the HDMI connector to get the image back. I don’t switch off the N2 because I’m using it headless during the day to listen to music, using the web interface or Yatse.
Thanks for your help.
Frédéric
