Frequent crashes
New here but hoping for some insight from people smarter than me. I have been running coreelec for several years on Minix boxes and until now, have not come across a problem I could not fix through stubborness and a little bit of luck.
Currently I am running correelec 21.2 from EMMC on a Minix U8K-Ultra. I use the Aeon MQ 9 skin.
I have been experiencing frequent crashes that can happen while watching a vide, oor while the box is idle.
I am hoping someone here will be able to look at my logs and recognize and point out what I cannot see and hopefully a solution.
Thank you for anyone that took the time to read this
If I’ve done this correctly the logs shoule be here:
https://paste.coreelec.org/ThroatsHostile
21.2?
:rofl:
When you would have read the CoreELEC Wiki you would know what to do.
Try on fresh install from USB or reset CE to factory settings.
I was trying to avoid that since rescanning library takes so long but I shall take your advice. Thank you for offering useful feedback!
Really helpful, thanks
He was prob suggesting you try the latest NO 22 ?
He was suggesting exactly what he said, read the wiki
But yes by reading the wiki the user would have to try 22
My apologies, I misunderstood the tone of your reply.
Thank you for helping to clarify. I will try 22
