Hi looking for G60s Pro bt .hwdb and remote.conf file please, thanks.
Still need helpwith this.
Hi thanks, How do I get it?
The link posted assumes the necessary file is already included in CoreELEC.
However, I have the same remote but the device identifier does not match with the one in the link.
This change remaps only the OK key to make it work as expected.
I had to use the following in my hwdb file:
evdev:input:b0005v2717p32C0*
KEYBOARD_KEY_c0041=enter
*you need a space before KEYBOARD_KEY…
you can find the correct device number for your device with evtest
then create a hwdb file under /storage/.config/hwdb.d/
execute the following commands
udevadm hwdb --update
udevadm trigger -s input
and reboot
Can you dm me yours please I’m not that technical, thanks.
