G7 Max s905x4 1gbit 4gigs mem basic config info
This may be of some help for some one out there as well; having struggled with a couple of config options from the standard s905x4 gbit 4GB dtb config.
first off, the remote control needs to be updated with the custom .toml file
ssh root@my-g7-max-ip-address
vi /storage/g7_max_smart_tv.toml
[[protocols]]
name = “G7 Max Smart TV Box”
protocol = “nec”
variant = “necx”
[protocols.scancodes]
0x9f70a = “KEY_POWER”
0x9f700 = “KEY_UP”
0x9f703 = “KEY_LEFT”
0x9f701 = “KEY_DOWN”
0x9f702 = “KEY_RIGHT”
0x9f71f = “KEY_OK”
0x9f71c = “KEY_BACK”
0x9f780 = “KEY_MENU”
0x9f70c = “KEY_HOME”
0x9f758 = “KEY_VOLUMEUP”
0x9f75d = “KEY_VOLUMEDOWN”
0x9f70d = “KEY_MUTE”
0x9f751 = “KEY_CHANNELUP”
0x9f752 = “KEY_CHANNELDOWN”
0x9f71b = “KEY_INFO”
0x9f71a = “KEY_CONTEXT_MENU”
enable the remote control with
vi /storage/.config/rc_maps.cfg
meson-ir * g7_max_smart_tv.toml
Configuration OpenVFD to display clock, cpu temp, or movie playback time
*Step 1) Install OpenVFD program add on option within Coreelec Repository within Kodi *
Step 2) vi /storage/.config/vfd.conf
# This file must be renamed to vfd.conf and placed in the /storage/.config/ folder.
# A95X F4 - S905X4 configuration
#gpio_xxx:
# [0] 0 = &gpio.
# [1] pin number - https://github.com/CoreELEC/linux-amlogic/blob/amlogic-4.9-19/include/dt-bindings/gpio/meson-sc2-gpio.h
# [2] Reserved - must be 0.
vfd_gpio_clk=‘0,35,0’
vfd_gpio_dat=‘0,36,0’
vfd_gpio_stb=‘0,0,0xff’
#chars:
# < DHHMM > Order of display chars (D=dots, represented by a single char)
vfd_chars=‘0,1,2,3,4’
#dot_bits:
# Order of dot bits. Typical configurations:
# Display Type 0, 1 usually has Alarm, USB, Play, Pause, Col, Ethernet, Wifi dots
# Alarm = 0, USB = 1, Play = 2, Pause = 3, Col = 4, Eth = 5, Wifi = 6
# Display Type 2 usually has APPS, USB, SETUP, CARD, Col, HDMI, CVBS dots
# APPS = 0, USB = 1, SETUP = 2, CARD = 3, Col = 4, HDMI = 5, CVBS = 6
# Display Type 3 Power, LAN, Col, Low Wifi, High Wifi
# N/A = 0, N/A = 1, Power = 2, LAN = 3, Col = 4, Low Wifi = 5, High Wifi = 6
vfd_dot_bits=‘0,1,2,3,4,5,6’
#display_type:
# [0] - Display type.
# [1] - Reserved - must be 0.
# [2] - Flags. (bit 0 = ‘1’ - Common Anode display, bits [1-7] - Reserved.)
# [3] - Controller.
vfd_display_type=‘0x01,0x00,0x00,0x06’
test vfd with command
systemctl restart openvfd; dmesg | tail -20
reboot
I also need to figure out on board bluetooth controller, this is currently not detected.
