Gemini man 4k 60fps
Just wanted to give a shoutout to the CoreELEC team. I just watched a horrible, but technically impressive movie from once esteemed director Ang Lee. My ODROID N2 played the 60fps movie flawlessly (9.2.1) and in stunning HDR.
The movie’s the best “stress test” for your device. Too bad there aren’t any real standout scenes other than the dirt bike sequence.
did you watched it via tv audio or amp audio. amp audio was out of sync even billy lynns 4k 60fps.
Can only agree,
The device is truly amazing, streaming without any issues what so ever:
passthrough audio to a soundbar (not sure if that’s a demanding task tho)
Bitrate 86 261 kbps
Size 72220MB
and yeah we don’t have to talk about the movie lol.
Same here. On odroid with the latest nightly 20200115 audio is out of sinc both via soundbar and the tv (Lg c8).
Also out of sync on Panasonic TV gx 810. and on both TV’s there are stutters in video.
yes tested on my lg e7 bypass amp same problem . seems like n2 got a problem playing 60fps file could the team look into this please tested with stable and nightly same results.
same here. Both Gemini man and Billy Lynn are 60fps and got the same problem on odroid N2 with stable 9.2.1 and the latest nightly. Pls devs have a look at this problem.
I’m not sure…but my audio was sync’d fine
i am all good now call it a blessing in disguise my n2 would not boot after update to latest nightly so i did a clean install back to the emmc. all my issues resolved 60fps plays fine now.
I have same problems.
Now works perfectly.
Changed HDMI cable between N2 -> Onkyo amplifier
So, cable is important on high bitrates :slight_smile:
File info:
Video
Format : HEVC
Format profile : Main 10@L5.1@High
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Duration : 1 h 57 min
Bit rate : 81.0 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 59.940 (60000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.163
Stream size : 66.2 GiB (94%)
Title : MPEG-H HEVC Video / 80973 kbps / 2160p / 59.940 fps / 16:9 / Main 10 @ Level 5.1 @ High / 10 bits / HDR10 / BT.2020
Language : English
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : Display P3
Mastering display luminance : min: 0.0010 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 5180 cd/m2
Maximum Frame-Average Light Level : 1577 cd/m2
Audio #1
Format : MLP FBA 16-ch
Format/Info : Meridian Lossless Packing FBA with 16-channel presentation
Commercial name : Dolby TrueHD with Dolby Atmos
Codec ID : A_TRUEHD
Bit rate mode : Variable
Bit rate : 4 204 kb/s
Maximum bit rate : 7 944 kb/s
Channel(s) : 8 channels
Channel layout : L R C LFE Ls Rs Lb Rb
Sampling rate : 48.0 kHz
Frame rate : 1 200.000 FPS (40 SPF)
Compression mode : Lossless
Stream size : 3.44 GiB (5%)
Title : Dolby TrueHD/Atmos Audio / 7.1 / 48 kHz / 4204 kbps / 24-bit
Language : English
Default : Yes
Forced : No
Number of dynamic objects : 11
Bed channel count : 1 channel
Bed channel configuration : LFE
