I no doubt should start a project on github for this. I’ll look into that after getting a bit more organized.
In the meantime, here’s another version with the following changes / “improvements”:
- bit more clear about several global variables, providing default assignments at the start
- progress bar is now just two rectangles, rather than being drawn with elipses
- handle cover art retrieval when playing via UPnP / DLNA
- if running on the same box as Kodi itself, retrieve cover art when using Airplay
I have a question outstanding on the Kodi forums (under Music Support) regarding that last point. When playing via Airplay, it seems that Kodi makes use of a temporary file named either airtunes_album_thumb.jpg
under /storage/.kodi/temp. The starting image path is then special://temp/airtunes_album_thumb.jpg
(or the other file type). Invoking PrepareDownload on that path does return what looks like contents to use for an URL, but trying to fetch it just yields a 401 error.
Anyway, here’s the update.
Cheers,
Matt
kody_panel.py
# MIT License
# Copyright (c) 2020 Matthew Lovell
# Permission is hereby granted, free of charge, to any person obtaining a copy
# of this software and associated documentation files (the "Software"), to deal
# in the Software without restriction, including without limitation the rights
# to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
# copies of the Software, and to permit persons to whom the Software is
# furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in all
# copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
# AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
# OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
# SOFTWARE.
from luma.core.interface.serial import spi
from luma.core.render import canvas
from luma.lcd.device import ili9341
from PIL import Image
from PIL import ImageDraw
from PIL import ImageFont
from datetime import datetime
import time
import logging
import requests
import json
import io
import re
import os
#base_url = "http://10.0.0.188:8080" # Odroid C4
base_url = "http://localhost:8080"
rpc_url = base_url + "/jsonrpc"
headers = {'content-type': 'application/json'}
frameSize = (320, 240)
thumb_height = 140;
last_image_path = ""
last_thumb = ""
# Thumbnail defaults
default_thumb = "./music_icon.png"
default_airplay = "./airplay_thumb.png"
special_re = re.compile('^special:\/\/temp\/(airtunes_album_thumb\.(png|jpg))')
# Audio/Video codec names
codec_name = {"ac3" : "DD",
"eac3" : "DD",
"dtshd_ma" : "DTS-MA",
"dca" : "DTS",
"truehd" : "DD-HD",
"aac" : "AAC",
"wmapro" : "WMA",
"mp3float" : "MP3",
"flac" : "FLAC",
"BXA" : "BXA",
"alac" : "ALAC",
"vorbis" : "OggV",
"dsd_lsbf_planar": "DSD",
"aac" : "AAC",
"pcm_s16be": "PCM",
"mp2" : "MP2",
"pcm_u8" : "PCM"}
# Handle to ILI9341-driven SPI panel via luma
serial = spi(port=0, device=0, gpio_DC=24, gpio_RST=25,
reset_hold_time=0.2, reset_release_time=0.2)
device = ili9341(serial, active_low=False, width=320, height=240,
# framebuffer="full_frame",
bus_speed_hz=32000000
# Track info fonts
font = ImageFont.truetype("FreeSans.ttf", 22, encoding='unic')
fontB = ImageFont.truetype("FreeSansBold.ttf", 22, encoding='unic')
font_sm = ImageFont.truetype("FreeSans.ttf", 18, encoding='unic')
font_tiny = ImageFont.truetype("FreeSans.ttf", 11)
# Font for time and track
font7S = ImageFont.truetype("DSEG14Classic-Regular.ttf", 32)
font7S_sm = ImageFont.truetype("DSEG14Classic-Regular.ttf", 11)
image = Image.new('RGB', (frameSize), 'black')
draw = ImageDraw.Draw(image)
def truncate_text(pil_draw, xy, text, fill, font):
truncating = 0
new_text = text
t_width, t_height = pil_draw.textsize(new_text, font)
while t_width > (frameSize[0] - 20):
truncating = 1
new_text = new_text[:-1]
if truncating:
new_text += "\u2026"
pil_draw.text(xy, new_text, fill, font)
def progress_bar(pil_draw, bgcolor, color, x, y, w, h, progress):
pil_draw.rectangle((x,y, x+w, y+h),fill=bgcolor)
if(progress<=0):
progress = 0.01
if(progress>1):
progress=1
w = w*progress
pil_draw.rectangle((x,y, x+w, y+h),fill=color)
def update_display():
global last_image_path
global last_thumb
draw.rectangle([(1,1), (frameSize[0]-2,frameSize[1]-2)], 'black', 'black')
payload = {
"jsonrpc": "2.0",
"method" : "Player.GetActivePlayers",
"id" : 3,
response = requests.post(rpc_url, data=json.dumps(payload), headers=headers).json()
if len(response['result']) == 0:
# Nothing playing
device.backlight(False)
# draw.text(( 5, 5), "Nothing playing", fill='white', font=font)
last_thumb = ""
elif response['result'][0]['type'] != 'audio':
# Not audio
#draw.text(( 5, 5), "Not audio playing", fill='white', font=font)
last_thumb = ""
else:
# Something's playing!
device.backlight(True)
payload = {
"jsonrpc": "2.0",
"method" : "XBMC.GetInfoLabels",
"params" : {"labels": ["MusicPlayer.Title",
"MusicPlayer.Album",
"MusicPlayer.Artist",
"MusicPlayer.Time",
"MusicPlayer.Duration",
"MusicPlayer.TrackNumber",
"MusicPlayer.Property(Role.Composer)",
"MusicPlayer.Codec",
"MusicPlayer.Year",
"MusicPlayer.Genre",
"MusicPlayer.Cover",
"id" : 4,
#print("Response: ", json.dumps(response))
info = response['result']
# progress bar
payload = {
"jsonrpc": "2.0",
"method" : "Player.GetProperties",
"params" : {
"playerid": 0,
"properties" : ["percentage"],
"id" : "prog",
if 'percentage' in response['result'].keys():
prog = float(response['result']['percentage']) / 100.0
else:
prog = -1;
# retrieve cover image from Kodi, if it exists and needs a refresh
image_set = False
if (info['MusicPlayer.Cover'] != '' and
info['MusicPlayer.Cover'] != 'DefaultAlbumCover.png' and
not special_re.match(info['MusicPlayer.Cover'])):
image_path = info['MusicPlayer.Cover']
#print("image_path : ", image_path) # debug info
if image_path == last_image_path:
image_set = True
else:
last_image_path = image_path
if image_path.startswith("http://"):
image_url = image_path
else:
payload = {
"jsonrpc": "2.0",
"method" : "Files.PrepareDownload",
"params" : {"path": image_path},
"id" : 5,
if ('details' in response['result'].keys() and
'path' in response['result']['details'].keys()) :
image_url = base_url + "/" + response['result']['details']['path']
#print("image_url : ", image_url) # debug info
r = requests.get(image_url, stream = True)
# check that the retrieval was successful
if r.status_code == 200:
try:
r.raw.decode_content = True
cover = Image.open(io.BytesIO(r.content))
# resize while maintaining aspect ratio
orig_w, orig_h = cover.size[0], cover.size[1]
shrink = (float(thumb_height)/orig_h)
new_width = int(float(orig_h)*float(shrink))
# just crop if the image turns out to be really wide
if new_width > 140:
thumb = cover.resize((new_width, thumb_height), Image.ANTIALIAS).crop((0,0,140,thumb_height))
else:
last_thumb = thumb
image_set = True
except:
cover = Image.open(default_thumb)
last_thumb = cover
image_set = True
if not image_set:
# is Airplay active?
if special_re.match(info['MusicPlayer.Cover']):
airplay_thumb = "/storage/.kodi/temp/" + special_re.match(info['MusicPlayer.Cover']).group(1)
if os.path.isfile(airplay_thumb):
last_image_path = airplay_thumb
else:
last_image_path = default_airplay
else:
# default image when no artwork is available
last_image_path = default_thumb
cover = Image.open(last_image_path)
cover.thumbnail((thumb_height, thumb_height))
last_thumb = cover
image_set = True
if image_set:
image.paste(last_thumb, (5, 5))
# progress bar and elapsed time
if prog != -1:
if info['MusicPlayer.Time'].count(":") == 2:
# longer bar for longer displayed time
progress_bar(draw, 'dimgrey', 'lightgreen', 150, 5, 164, 4, prog)
else:
progress_bar(draw, 'dimgrey', 'lightgreen', 150, 5, 104, 4, prog)
draw.text(( 148, 14), info['MusicPlayer.Time'], fill='lightgreen', font=font7S)
# track number
if info['MusicPlayer.TrackNumber'] != "":
draw.text(( 148, 60), "Track", fill='white', font=font_tiny)
draw.text(( 148, 73), info['MusicPlayer.TrackNumber'], fill='white', font=font7S)
# track title
truncate_text(draw, (5, 150), info['MusicPlayer.Title'], fill='white', font=font)
# other track information
truncate_text(draw, (5, 180), info['MusicPlayer.Album'], fill='white', font=font_sm)
if info['MusicPlayer.Artist'] != "":
truncate_text(draw, (5, 205), info['MusicPlayer.Artist'], fill='yellow', font=font_sm)
elif info['MusicPlayer.Property(Role.Composer)'] != "":
truncate_text(draw, (5, 205), "(" + info['MusicPlayer.Property(Role.Composer)'] + ")", fill='yellow', font=font_sm)
# audio info
codec = info['MusicPlayer.Codec']
if info['MusicPlayer.Duration'] != "":
draw.text(( 230, 60), info['MusicPlayer.Duration'], font=font_tiny)
if codec in codec_name.keys():
draw.text(( 230, 74), codec_name[codec], font=font_tiny)
if info['MusicPlayer.Genre'] != "":
draw.text(( 230, 88), info['MusicPlayer.Genre'][:15], font=font_tiny)
if info['MusicPlayer.Year'] != "":
draw.text(( 230, 102), info['MusicPlayer.Year'], font=font_tiny)
# Output to OLED/LCD display
device.display(image)
def main():
print(datetime.now(), "Starting")
# Turn down verbosity from http connections
logging.basicConfig()
logging.getLogger("urllib3").setLevel(logging.WARNING)
while True:
draw.text(( 5, 5), "Waiting to connect with Kodi...", fill='white', font=font)
while True:
# first ensure Kodi is up and accessible
payload = {
"jsonrpc": "2.0",
"method" : "JSONRPC.Ping",
"id" : 2,
try:
if response['result'] != 'pong':
print(datetime.now(), "Kodi not available via HTTP-transported JSON-RPC. Waiting...")
time.sleep(5)
else:
break
except:
time.sleep(5)
pass
print(datetime.now(), "Connected with Kodi. Entering display loop.")
while True:
try:
update_display()
except (ConnectionRefusedError,
requests.exceptions.ConnectionError):
print(datetime.now(), "Communication disrupted.")
break
time.sleep(0.9)
if __name__ == "__main__":
try:
main()
except KeyboardInterrupt:
print(datetime.now(), "Stopping")
pass
