Hi all, I have a GT King with CoreElec 9.2.2 and Kodi 18.6.
I’m trying to encode some UHD HDR BluRays with Handbrake and I stumbled on something strange: if I use the “h264 10bit” preset the .mkv is basically unplayable (enormous stuttering, sometimes almost to a halt).
On the other hand, if I use the “h265 10bit” preset (or any other non-10bit preset, h264 or 265) the file plays well.
H264 10 bit isnt hardware decoded by your box. No AMLOGIC chip support hardware decoding. Your box is decoding it by software - and choppy reproduction.
H265 10bit is hardware decoded thus fluent reproduction.
All formats should work except those which are not standard, and 10bit H264 is not standard.
Older formats/lower resolution should work fine with software decoding.
