GT King II Stock firmware
Thanks @rho-bot, it’s just really hard to get it from there, the slimbox site it’s much easy to download from. I’m already on 003R0, and as already mentioned. 003R0 is not a great version, video playback stutters a LOT!
I will wait until a flashable 006R0 IMG File coms around since ota fails me.
Thanks to @freddy how provided the maskrom points, I did need them at some point, and that was really helpful to have at hand.
I got the “GT-King II Version 1.2, beelink” and works absolutely the same on this version.
002RO beta and 006R0 update software works much better than 003RO.
You will update twice with 006R0 then it works fine. or it gives a ‘super partition’ error
How can I update it twice?
There is no recovery menu!
Using OTA update app, results in super partition error (and non booting android)
“super partition error” If you are encountering this error, reset and updaye again with the same firmware.
(I use google translate)
GTKINGII_Beelink006R0 Firmware if anyone else is needing it
