GT King II Stock firmware
Hi all,
I have tried to install the “GTKINGII_Beelink006R0” from the bee-link support site, and bricked my device with that. TV is only showing no signal. It can still boot into coreelec, telling me that there is no “super partition”.
So, I searching for the Stock android Rom for this Device my previous version was “003PO” I would like to go back to that. Or to a better stock ROM, is there is any?
If anyone has the stock rom of version “003PO” for the GT King II lying around and is willing to share it. I would highly appreciate it.
I know how to use the Amlogic USB Burning tool, just need the .img file.
Reinstall the GTKINGII_Beelink006R0 rom and the problem is solved.
Sure i would do that, but bee-link support site only has the update .ZIP (t7_an400_arm64-ota-eng.zrb.zip) file.
I can’t use this with the Amlogic USB Burning tool, that takes only .img files.
Try this maybe
Boot to recovery (toothpick method or other)
Use the function there to apply update from ext.
Also sometimes in system settings there is app to apply update ota zip
Of course you can’t, since this type of file is intended for OTA update, or via uSD card.
Use “Amlogic Burn Card Maker” program to burn this file to an uSD card. Place the card in your box and power it on. It should start updating automatically…
I was using the OTA app to install the update, when I got the message to restart the box.
After that, there is no picture and the box no longer boots.
I strongly advise against using the update app on a Bee-link device.
Thanks, i already know that.
Without an img file neither the “Amlogic USB Burning tool” or “Amlogic Burn Card Maker” will work.
img file
The link only shows:
Error 400
Bad Request
Wrong product
looking for an img file for the “Beelink GT-King 2” thats with A311D2 SoC
That is most unfortunate
Maybe you are only soft bricked??
See if you can boot to recovery
Wipe cache
Wipe parameter
Wipe data/factory reset
Other wise may need maskrom mode to flash
Dude, there is the original firmware (img) file in the link I gave.
Here is pics of test points for maskrom
Good luck
Hope you get it
Still needed? I might have 003 somewhere.
EDIT: Got 003R0
I now also have the 003R0 and 002RO beta, neither of which is suitable for my purposes.
I am looking for the 003PO with android tv play store preinstalled.
Yes, it’s soft bricked, you can’t boot into the recovery menu, because no image is displayed.
Maskrom mode is not necessary.
I also wrote to bee link support, who only referred me to the empty support page, where there is the ota but no img file.
Thanks for nothing beelink
I will probably get the khadas vim4, same chip but much easier to get software which hopefully works better than beelink gt king ii
Also:
Update from 003R0 with ota to 006R0: ends in soft bricked
Update from 002RO beta with ota to 006R0: ends in soft bricked
There is currently no way to update to 006R0 unless it is already installed on your box.
Solution: 1. wait until beelink releases an img file which is more up to date.
or 2: Use something else, the GT-King II is an alpha product and not ready.
003R0 and 003P0 are the same software, there is no difference.
002RO beta software is the most stable working software.
With the new update, they gave the update software which is 006R0 and it works smoothly.
After updating with 006R0, return to factory settings and update again with 006RO
Try with this link, it provides a recovery img “GTKINGII_Beelink003R0.img”.
