I have a gt king pro that gave some headaches. First it wouldn’t turn on at all, then all of the sudden I turned on and got stuck at the logo after it turns from green to gray.
Now that I’ve tried Coreelec both omega and nexus generic images and pasting the a922x gt king dtb file correctly it boots into a black screen.
I’ve also didn’t get any results by putting the sd card into a usb adapter, only by directly using the sd card with a large card reader that I got the black screen after the beelink logo.
Also the default bootloader refuses to load by using the toothpick reset method.
Is there anything I can do ?
Is my device bricked ?
If it does not boot to Android, it surely is…
You may have to find an android img for your device and use amlogic burning tool.
