I have a GT1-mini with 4Gb RAM and 64GB storage
Having tried booting from sd and usb with the g12a_s905x2_beelink_gt1_mini as per Device Trees suggestion in Wiki results in the unit not booting and always showing the Beeline Logo.
However, I was able to boot OK with the DTB file from “Beelink GT mini A” g12a_s905x2_beelink_gt_mini_a All seems to be working fine, Wifi, BT, USB ports.
19.5 and 20.0 can be booted with g12a_s905x2_beelink_gt_mini_a
9.2.8 boots wtih g12a_s905x2_beelink_gt1_mini_4g.dtb
Hopefully it would be helpful to someone.
UPD. the “Devices with SoC S905X2” 4G 1Gbit is a better fit. was able to install the system on eMMC
System is not supported: g12a_s905x2_4g_1gbit!
There is NO official support by Team CoreELEC
if you continue to run this tool!
Continue? [y]: y
eMMC size: 0x000e8f800000 [64GB]
Original partition table:
[mmcblk0p01] bootloader offset 0x000000000000, size 0x000000400000 [4 MB], unkn
[mmcblk0p02] reserved offset 0x000002400000, size 0x000004000000 [64 MB], unkn
[mmcblk0p03] cache offset 0x000006c00000, size 0x000046000000 [1120 MB], cache
[mmcblk0p04] env offset 0x00004d400000, size 0x000000800000 [8 MB], unkn
[mmcblk0p05] logo offset 0x00004e400000, size 0x000000800000 [8 MB], code
[mmcblk0p06] recovery offset 0x00004f400000, size 0x000001800000 [24 MB], code
[mmcblk0p07] misc offset 0x000051400000, size 0x000000800000 [8 MB], code
[mmcblk0p08] dto offset 0x000052400000, size 0x000000800000 [8 MB], code
[mmcblk0p09] cri_data offset 0x000053400000, size 0x000000800000 [8 MB], cache
[mmcblk0p10] param offset 0x000054400000, size 0x000001000000 [16 MB], cache
[mmcblk0p11] boot offset 0x000055c00000, size 0x000001000000 [16 MB], code
[mmcblk0p12] rsv offset 0x000057400000, size 0x000001000000 [16 MB], code
[mmcblk0p13] tee offset 0x000058c00000, size 0x000002000000 [32 MB], code
[mmcblk0p14] vendor offset 0x00005b400000, size 0x000010000000 [256 MB], code
[mmcblk0p15] odm offset 0x00006bc00000, size 0x000010000000 [256 MB], code
[mmcblk0p16] system offset 0x00007c400000, size 0x000074000000 [1856 MB], code
[mmcblk0p17] data offset 0x0000f0c00000, size 0x000d9ec00000 [55788 MB], data
