GTMedia X1 S905Y4-B
I was wondering if it would be possible for someone to check this boot log https://paste.coreelec.org/MalariaHorace to see if this device could load Kodi. After the first reboot CE resized the USB and rebooted but then it hangs on the spash screen after a few seconds. I can get ssh with textmode in config.ini to diagnose a few things.
The main reason for trying this device is to see if the internal ATSC tuner working with CE. It has both ATSC 1 and 3 in Android but I would be happy with ATSC 1.0, I am not sure if libdvbv5 supports ATSC 3.0. As often is the case the si2168 ATSC firmware seems to be the issue
Martin
Looks like your android is not compatible with CE.
Find another Image for your device.
Thanks but that won’t be possible this is a custom Android with a dedicated PVR I was just happy to use your CE Linux to boot it. I will continue this a side project to see if I can open /dev/dvb and run my backend PVR server standalone on it. I expect all the packages from your repo will work except Kodi and Kodi binaries.
Thanks for taking the time to look.
Martin
