Hi, just updated to ver .5 from .2
I have a 1080p Panasonic plasma tv
Whitelist sorted and all my vids are playing fine at 24p
However, GUI is only stable at 480p.
Was fine before update.
Looks like a timing issue, bits of interface are duplicated in various parts of the screen.
Please clarify what you mean: images, video of issue
Also do you use default skin?
I’ll add a screenshot later when at home. I’ve seen on another thread, that a reboot after resolution change may sort it.
Just rebooting now to see if it sorts itself out
Well there you go, reboot sorted it out
