It took me about 5 days, a few passion filled emails and shaking the right trees to get the file ![]()
Save that file as remote.conf
A post was merged into an existing topic: Ugoos AM8 installation
X96X10pro canāt boot coreelec from tf card, how can i do that? The system flashed in emmc is slimbox.
Go back to the OP
Post 1 and read install guide /hints
For example: did you use which device tree blob
Need the Ten cent Aurora 5x DTB
Thanks.
usb boot is okļ¼but it canāt boot from tf card.
I have the same issue with X96X10pro it wonāt boot from the SD card reader, but I do get a CoreELEC bootloader error. Putting the same SD card in a USB device it boots from USB 2 or 3. Where is the information in post #1 to boot from the internal SD reader.
When you use the Tencent Aurora 5x DTB what does not have a uSD slot at all how you expect it works on another device?
Portisch,regarding remote.conf, Ugoos UR-01 Iāve been trying to follow the instructions but not working your help would be appreciated.
when will the S928X support TrueHD and DTS-HD in CE 21 nightly?
Good to know since the X96X10pro has one. Hopefully there will be a more generic dtb in the future.
Got it, thanks a lot.
Looking forward to the officail dtb.
Maybe you should try to extract it from Android (Extracting .dtb file from a running Android OS - #3 by anon88919003) and provide it to the CE team?
Sure I can provide the CE team with whatever I can when they have time to work on this.
We have contact with X96 team, we have samples and we hope that on the next weeks we can have this device supported
niceļ¼thanksļ¼ ![]()
@Vasco do you guys want an Ugoos SK1 to develop on? I can send mine to you.
Hello, thank you for your continued support.
But I have a problem.
The device is am8 - coreceelec21 - latest night version.
1- The bluetooth does not connect properly with the ur02 remote.
2- - The most important problem - when advancing the movie 10 seconds, annoying interference appears.
The official dtb for x96x10pro is good.
remote file: https://raw.githubusercontent.com/CoreELEC/remotes/e13790f1c7f2591c20def22061985ab6c3ffc56a/AmRemote/X96/remote.conf
Thanks for the tip. Upgraded the dtb.img and now I can boot from SD card. Thanks CE team!
